Autorius Tema: Nokia mobiliųjų telefonų flash'inimas naudojant Phoenix programą.  (Skaityta 534800 kartus)
Neprisijungęs varnoo18
Įrašai: 11 | Karma: +0/-0
10 kreditai Žiūrėti inventorių Siųsti pinigus varnoo18
Ats.: Nokia telefonų flashinimas naudojant Phoenix programą
« Atsakymas #20 Įrašytas: Balandžio 27, 2009, 16:17 »
Flashing started
Backup not required
Flashing phone
Initializing
Loading image files...
Waiting for USB device. Press phone's power button (if you start from dead terminal)
ROM Boot Drivers loaded. Creating RAW connection
Connecting to device...
Connection opened
Connection opened to BootCode successfully
First wait command succeeded.
First wait command failed. Preparing for bootrom waiting loop ...
Flashing Secondary boot code: 14592 Bytes
Sending USB data: 28%
Sending USB data: 56%
Sending USB data: 84%
Sending USB data: 100%
Secondary boot loaded
Skipping USB handshake...
Flashing Update Server Data: 292480 Bytes
Sending USB data: 1%
Sending USB data: 11%
Sending USB data: 21%
Sending USB data: 31%
Sending USB data: 41%
Sending USB data: 50%
Sending USB data: 60%
Sending USB data: 70%
Sending USB data: 81%
Sending USB data: 91%
Flashing PASUB TOC Data: 59328 Bytes
Sending USB data: 7%
Sending USB data: 14%
Sending USB data: 35%
Sending USB data: 55%
Sending USB data: 62%
Sending USB data: 76%
Sending USB data: 83%
Sending USB data: 97%
Update server loaded
Waiting for Update Server to boot...
Closing connection
Connection opened
Asic CMT: Verifying communication to device...
Asic CMT: UA Protocol 1.0 detected.
Initializing Update Server....
Asic CMT: Selecting programming blocks...
Warning: PAPUBKEY already selected
Asic CMT: Start programming 29543 KB...
Asic CMT: Erasing rm303__03.63.mcusw
Asic CMT: Erasing area 1...
Asic CMT: Erasing area 2...
Asic CMT: Erasing area 3...
Asic CMT: Erasing area 4...
Asic CMT: Erasing area 5...
Asic CMT: Erasing area 6...
Asic CMT: Erasing rm303__03.63.ppm_m12
Asic CMT: Erasing rm303__03.63.image_m12_blue
Asic CMT: Programming rm303__03.63.mcusw
Asic CMT: Programming  0%
Asic CMT: Programming  2%
Asic CMT: Programming  4%
Asic CMT: Programming  6%
Asic CMT: Programming  8%
Asic CMT: Programming  10%
Asic CMT: Programming  12%
Asic CMT: Programming  14%
Asic CMT: Programming  16%
Asic CMT: Programming  18%
Asic CMT: Programming  20%
Asic CMT: Programming  22%
Asic CMT: Programming  24%
Asic CMT: Programming  26%
Asic CMT: Programming  28%
Asic CMT: Programming  30%
Asic CMT: Programming  32%
Asic CMT: Programming  34%
Asic CMT: Programming  36%
Asic CMT: Programming  38%
Asic CMT: Programming  40%
Asic CMT: Programming  42%
Asic CMT: Programming  44%
Asic CMT: Programming  46%
Asic CMT: Programming  48%
Asic CMT: Programming  50%
Asic CMT: Programming  52%
Asic CMT: Programming  54%
Asic CMT: Programming  56%
Asic CMT: Programming rm303__03.63.ppm_m12
Asic CMT: Programming  58%
Asic CMT: Programming  60%
Asic CMT: Programming  62%
Asic CMT: Programming  64%
Asic CMT: Programming  66%
Asic CMT: Programming  68%
Asic CMT: Programming  70%
Asic CMT: Programming  72%
Asic CMT: Programming rm303__03.63.image_m12_blue
Asic CMT: Programming  74%
Asic CMT: Programming  76%
Asic CMT: Programming  78%
Asic CMT: Programming  80%
Asic CMT: Programming  82%
Asic CMT: Programming  84%
Asic CMT: Programming  86%
Asic CMT: Programming  88%
Asic CMT: Programming  90%
Asic CMT: Programming  92%
Asic CMT: Programming  94%
Asic CMT: Programming  96%
Asic CMT: Programming  98%
Asic CMT: Programming  100%
Waiting for communication response: 25
Waiting for communication response: 24
Waiting for communication response: 23
Waiting for communication response: 22
Waiting for communication response: 21
Waiting for communication response: 20
Waiting for communication response: 19
Waiting for communication response: 18
Waiting for communication response: 17
Waiting for communication response: 16
Waiting for communication response: 15
Waiting for communication response: 14
Waiting for communication response: 13
Waiting for communication response: 12
Waiting for communication response: 11
Waiting for communication response: 10
Waiting for communication response: 9
Waiting for communication response: 8
Waiting for communication response: 7
Waiting for communication response: 6
Waiting for communication response: 5
Waiting for communication response: 4
Waiting for communication response: 3
Error 0x84009427 communicating to phone. Unable to verify comm.
Warning: Unable to communicate to product after flashing
Flashing phone
Initializing
Connection was already open...
Phone must be off to perform revive operation with USB
Unable to set the phone to flash mode. Unable to flash.
Flashing phone
Gal kas nutuokiat kas blogai? ir turite kokiu pasiulymu kaip tai sutvarkyti?
Visa istorija - nokia 5310XM atvesta is anglijos naudojama lietuvoja su turbo sim, bet buvau irases 9.** softa,  ir pastebejau, kad Turbo sim nebegaudo rysio, nete suzinojau, kad veikia turbo sum tik su 3.63 fw. teko meginti downgradinti, bet nepavyko mesdavo, kad norimas fw yra senesnis uz esama, formutavau tel, bet per dead telefono rezima neiseina pilnai instaliuoti fw. tai jei turit kokiu siulymu laukiu, aciu
« Atsakymas #21 Įrašytas: Balandžio 27, 2009, 16:20 »
BB5 telefonų fw downgradint galima tik su originaliu FPS-8.
Neprisijungęs zaliukas
Įrašai: 253 | Karma: +30/-8
« Atsakymas #22 Įrašytas: Balandžio 27, 2009, 18:26 »
neskiesk eina ir per usb kabeliu TIEK SU JAV TIEK SU Phoenix. tik kad eina 50ant50. pirmas bandymas nepavyko teko apsilankyt pas meistrelius
« Atsakymas #23 Įrašytas: Balandžio 27, 2009, 18:39 »
Deja tu skiedi. Čia kalbama apie Phoenix. Todėl ir sakau , kad BB5 telefonus downgradint galima tik su originaliu Phoenix. Su šioje temoje paminėtu - ne. O apie  kitus aš nekalbu. Nes tai tema apie Phoenix, o ne JAF.
Neprisijungęs JeMas
2 kreditai Žiūrėti inventorių Siųsti pinigus JeMas
« Atsakymas #24 Įrašytas: Balandžio 29, 2009, 16:35 »
Krč man nesigauna nesuprantu blem :/
viska darau kaip parasyta ir nieko. va tokie dalykai:
Pasirenku savo modeli
Tada connectiona
Tada firmware. Ten ta tritaski spaudziu
Is to saraso nezinau ka rinktis, nes baltic ar lithuania nera. tai bet koki imu, esmes tai nekeicia
Paspaudziu ok. ir man ismeta dvi lentele tokias pacias
tada grazina i sita langa
Ir kai spaudziu tritaski meta tokia lentele:
(Pziuret didesne foto spauskit desinni peles ir "view image")
Kokiu nors ideju? :/ nes telefonas nuluzes visai, negaliu ijungt apsoliuto. kai pajungi usb kas kazkiek laiko girdisi kad prisijungia atsijungia prisijungia atsijungia ir t.t.
« Paskutinį kartą keitė: Balandžio 29, 2009, 16:37 sukūrė JeMas »
« Atsakymas #25 Įrašytas: Balandžio 29, 2009, 17:29 »
Koks tel? 5200? Spėju ne viską instaliavai. Pabandyk rašyt 2009 phoenix.
Neprisijungęs JeMas
« Atsakymas #26 Įrašytas: Balandžio 29, 2009, 23:46 »
Hmmm... su 2009 bandziau
« Atsakymas #27 Įrašytas: Balandžio 30, 2009, 05:48 »
Tada viską trink ir pagal instrukciją 2008 rašyk.
Įrašyta: Balandis 30, 2009, 05:43
Tiesa, Net Framework 3.0 instaliuok.
Neprisijungęs eziux_666
Įrašai: 26 | Karma: +0/-0
9 kreditai Žiūrėti inventorių Siųsti pinigus eziux_666
« Atsakymas #28 Įrašytas: Gegužės 07, 2009, 19:44 »
Gal turit minčių, kas čia ne taip? Telefonas Nokia E50-1 RM-170.
Flashing started
Backup not required
Flashing phone
Initializing
Connection opened
Flashing Secondary boot code: 14464 Bytes
Sending USB data: 57%
Sending USB data: 85%
Flashing Update Server Data: 218112 Bytes
Sending USB data: 2%
Sending USB data: 30%
Sending USB data: 51%
Sending USB data: 71%
Sending USB data: 90%
Flashing PASUB TOC Data: 27904 Bytes
Sending USB data: 15%
Sending USB data: 29%
Sending USB data: 44%
Sending USB data: 59%
Sending USB data: 73%
Sending USB data: 88%
DEBUG - FUR_CONTROL_SYSTEM_INFO_REQ not supported on device. Skipping detection
Configuring Algorithm clients....
FUR: Adding Asic CMT as client 0x01...
FUR: PROTOCOL_CONTROL - Error sending message 0x0001 to Client 0x10 - 0x84009427
Error initializing Algorithm. 0x84009427
Flashing phone
Initializing
dar pora screen'ų:
http://www.sendspace.com/file/e3zowf
http://www.sendspace.com/file/izvti3
radau dar porą saitų su Nokia FW failais, gali ir kartotis:)
http://downloads.muthumobiles.org/index.php?dir=Nokia Flash_Files/BB5 Flash File/
http://www.ipmart-forum.com/showthread.php?t=216350&highlight=6270
Man tas pats, tik telefonas 6288. Windowsai Sp3. Ką daryti?
« Atsakymas #29 Įrašytas: Gegužės 07, 2009, 22:12 »
bandyk tada su JAF daryt . JAF ir palauko dead .
« Atsakymas #30 Įrašytas: Gegužės 08, 2009, 18:32 »
Gal galit man "žaliam" paaiškint, kas tas JAF ir kaip juo naudotis? :-[
Neprisijungęs excess
2 kreditai Žiūrėti inventorių Siųsti pinigus excess
« Atsakymas #31 Įrašytas: Gegužės 16, 2009, 02:26 »
Dėkui, padėjo, viskas dabar tvarkoj su telefonu, o jau meistrams norėjau nešt  :biggrin:
Susitvarkiau 6300, bet n70 nepataisomas( kaip ir sakė meistrai, tik dar pats norejau isitikint :D .)
Neprisijungęs meistrs :)
Įrašai: 283 | Karma: +5/-1
« Atsakymas #32 Įrašytas: Gegužės 31, 2009, 08:32 »
Patikslinsiu truputi, downgrade galimas tik su Phoenix development versija (flashinant) Kitas imanomas budas su sia programa tai atstatinejant sertifikatus Nokia online, tam reikia tureti kaip minimum FPS-10 ir security korta SX-4 su suteikta prieiga prie NOKIA servo (neimanomas variantas) FPS-8 jau mires reikalas ir dulkems tik tinkamas rinkti :). Siuo metu naudojami FPS-10 (nebegaminamas) ir FPS-21 (paskutinis produktas). Taip kad daug galvos nesukit del to downgrade su Phoenix, geriausia/paprasciausia  ta daro tik hakerski toolai :)
Neprisijungęs Ehoo
Įrašai: 10 | Karma: +0/-0
3 kreditai Žiūrėti inventorių Siųsti pinigus Ehoo
Ats.: Nokia telefonų flash'inimas naudojant Phoenix programą.
« Atsakymas #33 Įrašytas: Birželio 10, 2009, 12:38 »
sveiki. susuduriau su problema. parsisiunciau,isidiegiau viska kaip aprasyta. bandau flashint mirusi telefona,bet neduoda ir varneles uzdet kur dead phone... gal ka ne taip darau? telefonas-nokia 7210c
aciu uz atsakyma.
« Paskutinį kartą keitė: Birželio 10, 2009, 12:40 sukūrė Ehoo »
« Atsakymas #34 Įrašytas: Birželio 10, 2009, 14:00 »
Tai pirma fw pasirink, tada varnelę. Ir ar nustatęs no conecction?
Neprisijungęs Ehoo
« Atsakymas #35 Įrašytas: Birželio 10, 2009, 16:32 »
taip ir no conekt nustates ir fw pasirenku... nezinau kas daugiau ne taip. rm-436 pasirenku,kaip ir ant telefono parasyta.
« Atsakymas #36 Įrašytas: Birželio 10, 2009, 16:36 »
Padaryk screenshot'ą ir įmesk čia.
Neprisijungęs nextoff
Įrašai: 5 | Karma: +0/-0
8 kreditai Žiūrėti inventorių Siųsti pinigus nextoff
« Atsakymas #37 Įrašytas: Birželio 17, 2009, 00:18 »
Sveiki,
Turiu Nokia 6151 ir uzsikrauna tik baltas ekranas, kaip suprantu reikia perrasyti softa kaip dead phone. Darau viska pagal instrukcijas ir gaunu:
Flashing started
Backup not required
Flashing phone
Initializing
Connection opened
Flashing Update Server Data: 225152 Bytes
Sending USB data: 20%
Sending USB data: 40%
Sending USB data: 80%
Flashing PASUB TOC Data: 27968 Bytes
Closing connection
Connection opened
Waiting for communication response: 22.....
HRESULT 0x8401f121 (-2080247519)
Flash: Communication with phone is not possible. Unable to detect phone operation mode, cannot continue.
Gal turite kokui patarimu ar minciu?
Neprisijungęs welniukas
Įrašai: 32 | Karma: +2/-1
4 kreditai Žiūrėti inventorių Siųsti pinigus welniukas
« Atsakymas #38 Įrašytas: Birželio 19, 2009, 16:04 »
nesiuncia man to naujausio.raso tipo kad nera failo :(
Neprisijungęs reiwaz
Įrašai: 11 | Karma: +0/-1
2 kreditai Žiūrėti inventorių Siųsti pinigus reiwaz
« Atsakymas #39 Įrašytas: Birželio 24, 2009, 10:33 »
Sweiki.Mano tlf Nokia N70 RM-84.Viska padarau kaip rasoma gide bet kai reikia pasirinkti Product Code tokio kaip mano nera, o pasirinkus kita ismeta error.Gal zinot ka daryt?
