Autorius Tema: Nokia 5310, mire, reiktu prikelti  (Skaityta 19992 kartus)
Neprisijungęs varnoo18
Įrašai: 11 | Karma: +0/-0
10 kreditai Žiūrėti inventorių Siųsti pinigus varnoo18
« Įrašytas: Balandžio 27, 2009, 16:21 »
Flashing started
Backup not required
Flashing phone
Initializing
Loading image files...
Waiting for USB device. Press phone's power button (if you start from dead terminal)
ROM Boot Drivers loaded. Creating RAW connection
Connecting to device...
Connection opened
Connection opened to BootCode successfully
First wait command succeeded.
First wait command failed. Preparing for bootrom waiting loop ...
Flashing Secondary boot code: 14592 Bytes
Sending USB data: 28%
Sending USB data: 56%
Sending USB data: 84%
Sending USB data: 100%
Secondary boot loaded
Skipping USB handshake...
Flashing Update Server Data: 292480 Bytes
Sending USB data: 1%
Sending USB data: 11%
Sending USB data: 21%
Sending USB data: 31%
Sending USB data: 41%
Sending USB data: 50%
Sending USB data: 60%
Sending USB data: 70%
Sending USB data: 81%
Sending USB data: 91%
Flashing PASUB TOC Data: 59328 Bytes
Sending USB data: 7%
Sending USB data: 14%
Sending USB data: 35%
Sending USB data: 55%
Sending USB data: 62%
Sending USB data: 76%
Sending USB data: 83%
Sending USB data: 97%
Update server loaded
Waiting for Update Server to boot...
Closing connection
Connection opened
Asic CMT: Verifying communication to device...
Asic CMT: UA Protocol 1.0 detected.
Initializing Update Server....
Asic CMT: Selecting programming blocks...
Warning: PAPUBKEY already selected
Asic CMT: Start programming 29543 KB...
Asic CMT: Erasing rm303__03.63.mcusw
Asic CMT: Erasing area 1...
Asic CMT: Erasing area 2...
Asic CMT: Erasing area 3...
Asic CMT: Erasing area 4...
Asic CMT: Erasing area 5...
Asic CMT: Erasing area 6...
Asic CMT: Erasing rm303__03.63.ppm_m12
Asic CMT: Erasing rm303__03.63.image_m12_blue
Asic CMT: Programming rm303__03.63.mcusw
Asic CMT: Programming  0%
Asic CMT: Programming  2%
Asic CMT: Programming  4%
Asic CMT: Programming  6%
Asic CMT: Programming  8%
Asic CMT: Programming  10%
Asic CMT: Programming  12%
Asic CMT: Programming  14%
Asic CMT: Programming  16%
Asic CMT: Programming  18%
Asic CMT: Programming  20%
Asic CMT: Programming  22%
Asic CMT: Programming  24%
Asic CMT: Programming  26%
Asic CMT: Programming  28%
Asic CMT: Programming  30%
Asic CMT: Programming  32%
Asic CMT: Programming  34%
Asic CMT: Programming  36%
Asic CMT: Programming  38%
Asic CMT: Programming  40%
Asic CMT: Programming  42%
Asic CMT: Programming  44%
Asic CMT: Programming  46%
Asic CMT: Programming  48%
Asic CMT: Programming  50%
Asic CMT: Programming  52%
Asic CMT: Programming  54%
Asic CMT: Programming  56%
Asic CMT: Programming rm303__03.63.ppm_m12
Asic CMT: Programming  58%
Asic CMT: Programming  60%
Asic CMT: Programming  62%
Asic CMT: Programming  64%
Asic CMT: Programming  66%
Asic CMT: Programming  68%
Asic CMT: Programming  70%
Asic CMT: Programming  72%
Asic CMT: Programming rm303__03.63.image_m12_blue
Asic CMT: Programming  74%
Asic CMT: Programming  76%
Asic CMT: Programming  78%
Asic CMT: Programming  80%
Asic CMT: Programming  82%
Asic CMT: Programming  84%
Asic CMT: Programming  86%
Asic CMT: Programming  88%
Asic CMT: Programming  90%
Asic CMT: Programming  92%
Asic CMT: Programming  94%
Asic CMT: Programming  96%
Asic CMT: Programming  98%
Asic CMT: Programming  100%
Waiting for communication response: 25
Waiting for communication response: 24
Waiting for communication response: 23
Waiting for communication response: 22
Waiting for communication response: 21
Waiting for communication response: 20
Waiting for communication response: 19
Waiting for communication response: 18
Waiting for communication response: 17
Waiting for communication response: 16
Waiting for communication response: 15
Waiting for communication response: 14
Waiting for communication response: 13
Waiting for communication response: 12
Waiting for communication response: 11
Waiting for communication response: 10
Waiting for communication response: 9
Waiting for communication response: 8
Waiting for communication response: 7
Waiting for communication response: 6
Waiting for communication response: 5
Waiting for communication response: 4
Waiting for communication response: 3
Error 0x84009427 communicating to phone. Unable to verify comm.
Warning: Unable to communicate to product after flashing
Flashing phone
Initializing
Connection was already open...
Phone must be off to perform revive operation with USB
Unable to set the phone to flash mode. Unable to flash.
Flashing phone
Gal kas nutuokiat kas blogai? ir turite kokiu pasiulymu kaip tai sutvarkyti?
Visa istorija - nokia 5310XM atvesta is anglijos naudojama lietuvoja su turbo sim, bet buvau irases 9.** softa,  ir pastebejau, kad Turbo sim nebegaudo rysio, nete suzinojau, kad veikia turbo sum tik su 3.63 fw. teko meginti downgradinti, bet nepavyko mesdavo, kad norimas fw yra senesnis uz esama, formutavau tel, bet per dead telefono rezima neiseina pilnai instaliuoti fw. tai jei turit kokiu siulymu laukiu, aciu
Ats.: Nokia 5310, mire, reiktu prikelti
« Atsakymas #1 Įrašytas: Balandžio 27, 2009, 16:31 »
na siaip viskas cia del zeminimo. naujausia versija manau irasyt leis ir telefas atsigaus. Toliau du variantai arba atsirist pilnai arba zemint, bet zemina ne visi boxai gerai...kiek zemines 5310 tai man visada gerai suzemindavo mt boxas per usb kabeli.
« Atsakymas #2 Įrašytas: Balandžio 27, 2009, 16:56 »
O gal galetum apibudinti kaip ten reikia zeminti? Nenoriu vel klaidu padaryti, dekui
« Atsakymas #3 Įrašytas: Balandžio 27, 2009, 17:39 »
manau nesk meistrams nuzemins, jei turetum mt boxa manau tokiu klausimu nekiltu.. o jei nezinai kas tai yra paisnaudok google ir rasi atsakyma.
« Atsakymas #4 Įrašytas: Balandžio 27, 2009, 18:09 »
Tai ar apskritai yra kokia programa su kuria tai butu galima sutvarkyti?
« Atsakymas #5 Įrašytas: Balandžio 27, 2009, 18:15 »
JAF v1.98.32
Neprisijungęs zaliukas
Įrašai: 253 | Karma: +30/-8
« Atsakymas #6 Įrašytas: Balandžio 27, 2009, 18:20 »
JAF v1.98.32
deja jei tel mires J.A.V jo nemato. nes jungias per usb kabeli. P.S per Phoenix zemina. mirusio telefono ?
« Paskutinį kartą keitė: Balandžio 27, 2009, 18:23 sukūrė zaliukas »
« Atsakymas #7 Įrašytas: Balandžio 27, 2009, 18:22 »
O kas neleidžia su phoenix atgaivinus , downgradint su  JAF?
« Atsakymas #8 Įrašytas: Balandžio 27, 2009, 22:27 »
Kad as su tuoj JAF meginu bet man jo net nepaleidzia, gal galit kas duoti normalu setum ir kazkoki P-key, kad pasileistu, os su pheonix gal ir tiesa sakot kad iseitu prikelt, bet ten pradzioj nucopinau, kas vyksta kai pasirenku dead phone rezima, kazko neranda ant galo, gal turit kokiu minciu? is anksto dekoju
Įrašyta: Balandis 27, 2009, 19:34
Va katik isirasiau 9.42 FW, belieka sumazinti iki 3.63. Gal kas galite padeti? labai buciau dekingas, aciu
« Atsakymas #9 Įrašytas: Balandžio 27, 2009, 23:12 »
o tu ijungi telefona kaip papraso phoenix?
« Atsakymas #10 Įrašytas: Balandžio 27, 2009, 23:22 »
Jo, jau sutvarkiau, bet man reikia dabar zeminti fw, ieskau pagalbos...
« Atsakymas #11 Įrašytas: Balandžio 28, 2009, 08:25 »
na su mt boxu zeminimas toks, parenki versija zemesne, prijungi prie usb ir spaudi BB5 downgrade...bet berods kad ir tik flash spaustum irgi viskas normaliai susizemintu
« Atsakymas #12 Įrašytas: Balandžio 28, 2009, 10:48 »
tai jei tau jau telefonas isijungia viskas normaliai. tai bandyt dabar su JAF zemint. man zeminant numire telefas. teko pas meistreli nest. pazystamui nusizemino su JAF is 3 trys kartai. jei reikia .imk idejau JAF ir truputis info apie ja. Firmvaro_downgraidinimas.rar - 21.6 Mb jei reikia sakyk idesiu firmwara exe formatu. lengviau bus
« Atsakymas #13 Įrašytas: Balandžio 28, 2009, 12:24 »
Na fw turiu exe formatu, meginsiu bandyti zeminti, tikiuosi pavyks
« Atsakymas #14 Įrašytas: Balandžio 28, 2009, 12:40 »
tik ant tel bandant zemint FW nustatyk pc suite rezima terp tel ir padaryk kad klaustu koki rezima pasirinkt prijungiant prie pc. ir kaip jau viska padarysi ismes lentele warning warning warning. tai nieko nespausk , telefonas persikraus  kaip susijungs su pc viska, tada tik spausk ok ar yes.,nes jei padarai ,kad telefonas susijungtu su pc automatiskai ,  su JAF kazkas blogai gaunas.
« Atsakymas #15 Įrašytas: Balandžio 28, 2009, 13:26 »
Na kiek pastoviai meginu tai man tipo neranda kazko, nelabai suprantu
Įrašyta: Balandis 28, 2009, 13:07
JAF version 1.98.47
Detected PKEY: 90012345
Card life counter: 100.00%
P-key nokia module version 01.01
FBUS INTERFACE NOT CONNECTED!!!
Changing mode...Done!
Changing mode...
Detected P-KEY: 90012345
Init usb communication...
Done!
Failed...IMEI
Failed...IMEI
Failed...IMEI
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-303\rm303__03.63.mcusw
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-303\rm303__03.63.ppm_a
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-303\rm303__03.63.image_a_red
Languages in ppm: English,Finish,Swedish,Danish,Norwegian,German,Icelandic
Backing up CRT...
Reading IMEI...
Failed! Aborting!
Failed to backup CRT...
Preparing for downgrade...
Failed to prepare for downgrade...
Searching for phone...Detected P-KEY: 90012345
Found
Reading SW version...Error reading ape ver!
cia su JAF gal numanai kas ne taip?
« Atsakymas #16 Įrašytas: Balandžio 28, 2009, 13:39 »
visu pirma viska istrini kas susije su Phoenix ir istrini likusius per run>regedit. ir toliau darai viska kaip parasiau.o telefonas jau pilnumoj uzsikrauna? jei ka rasyk i skaipa . nicas . zaliuks
« Atsakymas #17 Įrašytas: Balandžio 29, 2009, 07:31 »
Jolki palki, ne paprasciau ta telefona normaliai atristi, nei kelnes per galva mautis?
« Atsakymas #18 Įrašytas: Balandžio 29, 2009, 08:21 »
Pritariu, bet gal zmogui jau cia principo reikalas  :D
« Atsakymas #19 Įrašytas: Balandžio 29, 2009, 11:01 »
viskas gerai yra. jau grazinom firmware i 3.63 versijos. bet tik db nerandam  tokio firmwaro exe formatu,kad butu lt kalba. :) gal kas turit? :)
