Autorius Tema: LG km900 arnea atrišimas/unlocking (išspręsta)  (Skaityta 11357 kartus)
Neprisijungęs andriux-pa
Įrašai: 41 | Karma: +0/-1
16 kreditai Žiūrėti inventorių Siųsti pinigus andriux-pa
« Įrašytas: Birželio 13, 2010, 17:23 »
esmė tame, kad nusipirkau naują, atrištą telefoną ir sugalvojau atnaujinti jį per LG svetainę, kai atnaujino, jis vėl prisirišo. gal kas žinote ir galite padėti atsirišti telefoną?
tai vat, telefoną atsirišau, tiksliau pririšau prie savo tinklo(omnitel) :D jei reiks kam pagalbos kreipkitės į skype andriukas77, o šeip tai va tutorialas:
Hi everyone !
Just a few words before starting the tutorial :
This method does not yet allow you to totally SIM-UNLOCK your phone, but allows you to choose which operator you want to work with. This is repetible as many time as you can, so it's still pretty good (but you wont be able to use another operator if you are not near your computer). Hopefully with a little more work, we'll be able to have our phones unlock for severall operators, or even all operators.
I'd also like to thank : kingrz, art903, BlackHorn and Lolo-674, pbalanq, -The_King- for their direct or indirect help.
Now, let's get started :
0 - You will need
    * USB drivers :http://csmg.lgmobile.com:9002/swdata/USBSW/GSM/EE/LGUSBModemDriver_WHQL_ML_Ver_4.9.7_All_Win7_IFX20100222.zip
    * FlashTool E2 :http://www.zshare.net/download/63365767900c80dc/
    * This dll (version 4.32.0.0) :http://www.megaupload.com/?d=KNJLLAP7 Replace the one in FlashTool E2 file once installed by this one.
    * EditHexa :http://www.logitheque.com/logiciels/windows/utilitaires/editeur_hexadecimal/telechargement_edithexa_9903.htm or any Hexa editor (this one is in French Smiley
    * "EBL.fls" file :http://www.file-upload.net/download-1752346/06_BB_MPEH.fls.html
    * "KM900.flb" file : http://www.file-upload.net/download-1752277/01_psi_large_block_16_bit_paging.flb.html
Install everything on your computer (If your experiencing troubles during the process, try to uninstall everything from LG (including PC SUITE), reboot, reinstall USB drivers, and try again)
1 - Upload the STATIC_EEP part from your phone
1.1
Start Flash Tool E2
Go to File>Settings
   On the tab "Setup", check that the Binary Mode is enabled
   On the tab "Auto Start" select Auto Start (DSR / USB Detection)
1.2
On the main screen, go to the binary tab.
Select NAND as a Flash Type, and go on the Upload tab
On "Destination Binary File", put the path of the file as you want to save it (e.g. : C:\STATIC_EEP.bin)
On "EBL Reference File" Select the file "06_BB_MPEH.fls"
Put 0x544FC000 as a start adress
and 0x00014000 as a length
Put Infineon USB driver as a Communication Driver
1.3
Go to File>USB Map Wizard
Click on Next
Plug in your phone(Off, without battery, without sim card)
When your phone is recognized, click on done and then unplug it
1.4
Click on Start
Click on Yes
Plug in your Phone(Off, without battery, without sim card) on the same slot where you had it recognized (you have 10 sec before time out / can be modified on the setting menu)
The uploading of your static EEP Part should be happening
Go on the path that you choosed before, and your STATIC_EEP should be there !
2 - Choose your operator
2.1
The file you have is in fact your STATIC_EEP merged with your 06_BB_MPEH.fls, therefore, only the first 80Ko are interesting for us.
Open the file with your Hexadecimal Editor.
2.2
Go to this link http://en.wikipedia.org/wiki/Mobile_Network_Code and find your operator code(the one you use, and the one you want to use)-(if longer than 5 digits, take the first 5)
2.3
Look in the hexadecimal editor for your operator code (Value should be starting at offset = 00000E50 column 2, and has a length of 5)
Replace it by the operator code you want to use (if typing it in decimal, change the value and the decimal part of your editor)
[Note : I'm looking either for a generic operator code, or a way to put several operators in a row in this space (separator between two operators ?) Thanks for any help(the static eep part of an unlocked phone could help ;-)]
Save your file
3 - Download the STATIC_EEP part to your phone
3.1
Go back on FlashTool_E2
Still in Binary mode, choose Flash type = NOR and Download tab
"Projet (Hardware Setup)"= Use External File, and go and select "01_psi_large_block_16_bit_paging.flb"
Choose the STATIC_EEP file you saved as a binary file
3.2
Click on Start
Click on Yes
The downloading of your static EEP Part should be happening.
Once the computer says the transfer is ok, disconnect your phone, put your new SIM card in, your battery, and it should work !!!
A few last words :
The tutorial with screenshots will come later
Please let me know if you have any problems, if I forgot anything, or for any orthographic/grammatical mystake, broken links...
Feel free to help me improve this tutorial
Enjoy'
GaBZo
« Paskutinį kartą keitė: Birželio 15, 2010, 10:36 sukūrė andriux-pa »
Ats.: LG km900 arnea kaip atrišti nuo vadafone?
« Atsakymas #1 Įrašytas: Birželio 14, 2010, 01:47 »
You need tool like Vygis ( LG activated ), Z3x ( LG activated ) or Furious or something like ... or use services from allgsmunlock.com or just jump to nearest GSM workshop - they will unlock your Arena phone ...
paciam nelabai ..
« Atsakymas #2 Įrašytas: Birželio 14, 2010, 08:55 »
turėjau omeny pačiam ir nemokamai. flashint jei instrukcijos būtų sugebėčiau.. skaičiau žmonės pasidaro, o kaip? nesupratau, nes info labai mažai
« Atsakymas #3 Įrašytas: Birželio 14, 2010, 15:43 »
reikia tau box'o, jei neturi tada per interneta pirk ta koda, jei netinka tada nesk meistram  :)
« Atsakymas #4 Įrašytas: Birželio 14, 2010, 15:57 »
pasirodo būdas toks yra.. tik gal kas žino, kaip pasižiūrėt, prie kokio operatoriaus pririštas telefonas?
« Atsakymas #5 Įrašytas: Birželio 14, 2010, 16:04 »
taigi pats rasei nuo vodafone.. ijunk ir paziurek koki logotipa rodys, arba koks logotipas ant korpuso
« Atsakymas #6 Įrašytas: Birželio 14, 2010, 16:42 »
bet kokios šalies tai nežinau
« Atsakymas #7 Įrašytas: Birželio 14, 2010, 20:26 »
lt meniu buvo?
« Atsakymas #8 Įrašytas: Birželio 15, 2010, 08:44 »
na klausi ne salies o operatoriaus :)
