Autorius Tema: Android iš 2.1 i 2.2  (Skaityta 24880 kartus)
Neprisijungęs TautvydasM.
Įrašai: 55 | Karma: +3/-3 | Lytis: Vyras
4 kreditai Žiūrėti inventorių Siųsti pinigus TautvydasM.
« Įrašytas: Birželio 01, 2011, 19:42 »
Sveiki,noriu perrašyti iš 2.1 versijos i 2.2 bet neatrandu kaip taip padaryti,gal yra pamoka?
Telefonas Huawei u8220.
Neprisijungęs ConnectIT
Linux/FF/Apple/Nokia |
Ats.: Android iš 2.1 i 2.2
« Atsakymas #1 Įrašytas: Birželio 01, 2011, 21:42 »
Labas.
huaweidevice.com - Service Center - kernel-2.6.29-U82x0- Ecalir.zip
1. Copy dload to SD card
2. Switch off the handset ,then press "Volume Control Upper Key +End Key+ Power Key"
3. Showing successful
4. Remove battery one second ,then power on ,waiting till the OS start up
Normal Download
1: Copy dload to SD card
2: Settings Icon->SD card & Phone storage ->Software Upgrade
How to install
To install the firmware you will need:
    A fully charged battery
    A Micro SD memory card with more than 256mb of free space.
Then follow the steps below to flash your phone:
    Download and unzip the file to a location of your choice on your computer
    Copy the files you just unzipped (the ´dload¡ folder and all its contents) to the root directory of your MICRO SD card
    Insert your MICRO SD card into the handset
    Turn on your phone whilst holding both the End-Call (Red) and Volume-Up keys.
    As the update progresses you will see several screens along with a progress bar
    Once complete you will see a confirmation screen, and your phone will automatically restart.
Sėkmės! ;)
Neprisijungęs ecigonas
Įrašai: 38 | Karma: +1/-5
21 kreditai Žiūrėti inventorių Siųsti pinigus ecigonas
« Atsakymas #2 Įrašytas: Birželio 03, 2011, 17:47 »
Labas.
Normal Download
How to install
    Copy the files you just unzipped (the “dload” folder and all its contents) to the root directory of your MICRO SD card
Sėkmės! ;)
Kad nekurti naujos temos htc smart irgi tinka sitas varijantas?
« Atsakymas #3 Įrašytas: Birželio 03, 2011, 20:52 »
Su HTC telefonais sudetingiau, bet panasiai.
Neprisijungęs Paulius295
Įrašai: 5 | Karma: +0/-1
1 kreditai Žiūrėti inventorių Siųsti pinigus Paulius295
« Atsakymas #4 Įrašytas: Birželio 06, 2011, 10:51 »
kur rasti dload ka ?
« Atsakymas #5 Įrašytas: Birželio 06, 2011, 12:24 »
Manau. kad čia dload = download, downloaded...
Todėl pabandyk išarchyvuoti tai, ką parsisiuntei (visus katalogus ir bylas) tiesiai į atminties kortelę. Kopijuok ne archyvą ir ne į kokį katalogą, o kortelės pradžioje, kad būtų visi katalogai ir bylos iš archyvo tiesiog įkelti parsiųstą archyvą (arba archyvą, kuris bus parsiųsto archyvo viduje) ne į kokį katalogą, o kortelės pradžioje.
« Paskutinį kartą keitė: Birželio 07, 2011, 16:41 sukūrė ConnectIT »
« Atsakymas #6 Įrašytas: Birželio 06, 2011, 22:40 »
Tai ka parsisiunte, t.y. greiciausia ZIP arhyva - ji ir reikia deti, ne isarchyvuota. Tai butu i korteles saknini kataloga dedam update.zip ir idejus kortele i telefona:
« Atsakymas #7 Įrašytas: Birželio 07, 2011, 09:52 »
Čia rimtai? Nu dar nesu matęs, kad įkrovos instaliacija iš uždaro archyvo pasileistų... Nei Win OS, nei MAC OS, nei kitos OS... Na, nebent jis bootina iš telefono, o ne iš kortelės ir update'ą išsiarchyvuoja paskui. Tai tokiu atveju pasitaisau ir atsiprašau. :)
« Atsakymas #8 Įrašytas: Birželio 07, 2011, 16:04 »
Tada dar labai daug neesi ko mates.... Daugeliui HTC androidiniu telefonu galima perrasyti softa per hboot is atm. korteles ir tam naudojamas xxxx.zip archyvas (xxxx - modelio pavadinimo kodas). Taip pat ir atnaujinimai- update.zip, per recovery.
« Atsakymas #9 Įrašytas: Birželio 07, 2011, 16:23 »
Na taip. Bet pradinė įkrova vyksta iš hboot ar recovery, o ne *.zip archyvas pats save išsiarchyvuoja ir užsiloadina. Todėl neteisingai pamaniau, kad boot'ina iš kortelės. Tokiu atveju bootloader'is negali būti suarchyvuotas. Sorry, nėra patirties su Android. :)
« Atsakymas #10 Įrašytas: Birželio 07, 2011, 20:13 »
o kas gali but bandziau atsinaujinti i 2.2 versija viskas atsinaujino bet rodo vistiek kad sena versija tipo
« Atsakymas #11 Įrašytas: Birželio 08, 2011, 07:27 »
Nu kodel klausima reikia uzduoti kaip ekstrasensams? Aprasai normaliai viska ka darei konkreciai- tada gali tiketis kazkokio atsakymo... Dabar- pasikeiciau rata dviraciui- jis vistiek nevaziuoja, kame bedos?......
« Atsakymas #12 Įrašytas: Birželio 08, 2011, 12:44 »
To get your phone into Software Upgrade mode, power off your phone, and while holding "End Call (Red)" and "Volume Up", press the Power key to turn your phone back on
« Atsakymas #13 Įrašytas: Birželio 08, 2011, 18:41 »
Pats supratai ka cia parasei ir kaip konkreciai tai naudojama?
« Atsakymas #14 Įrašytas: Birželio 09, 2011, 21:54 »
Atnaujinau softa is tinklapio htc.com i 2,2versija viskas atsinaujino bet versija vistiek liko tipo 1,5 rodo taip. Bet telefone atsinaujino viskas ir atsirado nauju funkciju ir isvaizda atsinaujino ir t.t. O bandant atnaujinti vel isnaujo raso kad nera dar naujesnes versijos i kuria butu galima atnaujinti tipo sita pati naujausia. Tai ir klausiu kodel taip yra?
P.S. Jei jau dabar nesupranti tai tada nezinau kaip dar kitaip tau paaiskinti
« Atsakymas #15 Įrašytas: Birželio 10, 2011, 07:27 »
Na sunku pasakyti kodel taip.... Galbut telefone buvo perrasytas softas anksciau, kito regiono, ir del to yra neatitikimu. Kitos priezasties nelabai galiu sugalvoti.
« Atsakymas #16 Įrašytas: Birželio 22, 2011, 12:50 »
gal kas gali padėt isirašiau android 2.2 bet wifi neveike ką man dabar dariti ? :(
Įrašyta: Birželis 21, 2011, 20:34
http://dl.dropbox.com/u/5864262/Blog/CM6.1-Pulse-beta-0.40.zip is cia android 2.2 siunciausi
« Atsakymas #17 Įrašytas: Birželio 22, 2011, 13:02 »
O iš ko sprendi, kad neveikia? Gal tik išjungtas... Koks įrenginys? Pasižiūrėk nustatymus, pasiskaityk instrukciją...
« Atsakymas #18 Įrašytas: Birželio 26, 2011, 13:07 »
nėra Mac adreso ir Ip adreso rodo unavailable
Neprisijungęs dedulinas
Vat kaip buna:D
« Atsakymas #19 Įrašytas: Birželio 26, 2011, 13:27 »
rasyk senaji atgal ;)
