Autorius Tema: from avi to 3gp  (Skaityta 25854 kartus)
Neprisijungęs yplon
Įrašai: 109 | Karma: +0/-5
36 kreditai Žiūrėti inventorių Siųsti pinigus yplon
from avi to 3gp
« Įrašytas: Sausio 25, 2008, 14:58 »
Gal kas zinot koki gera converteri, kuris konvertuoja is .avi i .3gp ? Zinoma noreciau kad butu geresne kokybe...bet ka ten gausi gero su tuo 3gp...
P.S. mano mobas: SE k750i, taigi laukiu geresniu pasiulymu bei programu ;) ac.
  • Speed Dial
Neprisijungęs Denukas
Ats.: from avi to 3gp
« Atsakymas #1 Įrašytas: Sausio 25, 2008, 15:43 »
ImTOO 3GP Video Converter 2.1.55 build 1205b
Licenzija:
License Code:429300258809671278566D94-DF0F-7DC7-EA4A
Specification
Supported file format
Video:
Input:
MPEG(mpg, mpeg, dat, vob); WMV; ASF; AVI; QuichTime(mov, qt); MPEG4(mp4); 3GP; DV(dv, dif); Real Video(rm); Animated GIF(gif - decoding only); Macromedia Flash(swf - decoding audio only);
Output:
3GP, AVI, MPEG
Audio:
Input:
MPEG Audio(mp2, mp3); WMA; WAV; AU; MPEG4 Audio(m4a); Real Audio(ra); OGG; AAC; Raw AC3(ac3); NUT Open Container Format(nut);
Output:
MP3, WAV
Supported video and audio codecs
Video codecs:
MPEG1 video; MPEG2 video; MPEG4(DivX4/DivX5); MSMPEG4 V1; MSMPEG4 V2; MSMPEG4 V3(DivX3); WMV7; WMV8; H263(+)(Real Video 1.0); MJPEG; Lossless MJPEG; Apple MJPEG-B; Sunplus MJPEG; DV; Huff YUV; Asus v1; Asus v2; Creative YUV; H.264; Sorenson Video 1; Sorenson Video 3; On2 VP3; Theora; Intel Indeo 3; FLV; ATI VCR1; ATI VCR2; Cirrus Logic AccuPak; 4X Video; Sony Playstation MDEC; Id RoQ; Xan/WC3; Interplay Video; Apple Animation; Apple Graphics; Apple Video; Cinepak; Microsoft RLE; Microsoft Video-1; Westwood VQA; Id Cinematic Video; Planar RGB; FLIC video; Duck TrueMotion v1; VMD Video; MSZH; ZLIB; TechSmith Camtasia; IBM Ultimotion;
Audio codecs:
MPEG audio layer 2; MPEG audio layer 1/3; AC3; Vorbis; WMA V1/V2; AAC; Microsoft ADPCM; MS IMA ADPCM; QT IMA ADPCM; 4X IMA ADPCM; G.726 ADPCM; Duck DK3 IMA ADPCM; Duck DK4 IMA ADPCM; Westwood Studios IMA ADPCM; SMJPEG IMA ADPCM; CD-ROM XA ADPCM; CRI ADX ADPCM; Electronic Arts ADPCM; RA144; RA288; RADnet; AMR-NB; AMR-WB; DV audio; Id RoQ DPCM; Interplay MVE DPCM; Xan DPCM; Apple MACE 3; Apple MACE 6; FLAC;
System requirements
Windows 98/Me or Windows 2000/XP or better
>750MHz Intel or AMD CPU
« Atsakymas #2 Įrašytas: Sausio 25, 2008, 16:27 »
as ant motorolos v3i pasidarydaau 3gp klipa jis sverdavo 25 mb kokybe ir garsas budavo idealus tas pats kaip avi  :)
Neprisijungęs yplon
« Atsakymas #3 Įrašytas: Sausio 25, 2008, 16:29 »
su kokia programa ir kokie nustatymai ?
  • MOBILES.LT
Neprisijungęs Miscreated
« Atsakymas #4 Įrašytas: Sausio 25, 2008, 16:30 »
SUPER - labai geras konverteris. Konvertuoja iš daug formatų taip pat į daug formatų.
http://www.erightsoft.com/SUPER.html
  • iPhone 4
« Atsakymas #5 Įrašytas: Sausio 25, 2008, 17:02 »
nebepamenu koks konverteris bet viska ant maximum sukeldavau, garsas neatsilikdavo viskas veikdavo gerai cia manau ant bet kokio konverterio taip pasidarysi
  • westsite
Neprisijungęs mamutas112
mano telas |
from avi to 3gp
« Atsakymas #6 Įrašytas: Sausio 25, 2008, 17:06 »
As su nokia pc suite konwertuoju ir ir wisx ciki gaunasi
Mamutai dar neismire:D
Neprisijungęs yplon
« Atsakymas #7 Įrašytas: Sausio 25, 2008, 17:25 »
ten yra kazkas tokio kaip "download" ? nes nlb randu...
beje noreciau dar paklaust su kokia programa butu galima iskirpt video ? tarkim as nenoriu viso filmo, o tik kazkoki epizoda...ir kaip sumazint rezoliucija (176x220) ?
« Paskutinį kartą keitė: Sausio 25, 2008, 17:31 sukūrė yplon »
  • Speed Dial
« Atsakymas #8 Įrašytas: Sausio 25, 2008, 18:01 »
Su mano pamineta programa gali. Beto ne visi 176x220 rez telefonai palaiko toki video dydi, pvz: K750, w800, w810 palaiko tik 176x144.
Neprisijungęs yplon
« Atsakymas #9 Įrašytas: Sausio 25, 2008, 18:11 »
o kaip ten su tavo ta programa karpyt ir panasiai...? ;] as iskonvertinau kazka, idejau i moba, bet nepasileidzia...raso jog negalima paleist sio failo...
  • Speed Dial
« Atsakymas #10 Įrašytas: Sausio 25, 2008, 18:15 »
Ten virsuj pasirenki nuo kada iki kada konvertuoti. Gal tu codekus blogus parinkai?
Neprisijungęs yplon
« Atsakymas #11 Įrašytas: Sausio 25, 2008, 18:18 »
kzn...as nieko nekeiciau, iskart spaudziau "encode..."
zodziu pasakyk man visus nustatymus super duper ;) dekui...
  • Speed Dial
« Atsakymas #12 Įrašytas: Sausio 25, 2008, 18:20 »
Koks pas tave telefonas ir i koki formata nori konvertuoti?
Neprisijungęs yplon
« Atsakymas #13 Įrašytas: Sausio 25, 2008, 18:23 »
SE k750i, noriu is avi i 3gp
  • Speed Dial
« Atsakymas #14 Įrašytas: Sausio 25, 2008, 18:35 »
Siaip siulyciau tau convertuot i mp4.
3GPP format (*.3gp):
Video codec: h263
Video size: 176x144
Bit rate: 128-196
Frame rate: 15-20
Audio codec: amr_nb
Bit rate: 16
Sample rate: 16000-32000
Viso kito nekeisk!!!
Neprisijungęs yplon
« Atsakymas #15 Įrašytas: Sausio 25, 2008, 18:43 »
viska taip ir padariau ir raso "Fail" kai spaudziu "Encode"
o mp4 SE k750i palaiko ?
  • Speed Dial
« Atsakymas #16 Įrašytas: Sausio 25, 2008, 19:01 »
Palaiko.
MPEG-4 video format (*.mp4)
Video:
Video size: 176x144
Bit rate: 128-196
Frame rate: 20
Audio:
Bit rate: 32-64
Channels: Stereo
Neprisijungęs yplon
« Atsakymas #17 Įrašytas: Sausio 25, 2008, 19:05 »
na dbr kokybe afigena, bet vaizdas ziauriai atsilieka nuo garso...
  • Speed Dial
« Atsakymas #18 Įrašytas: Sausio 25, 2008, 19:14 »
Tai daryk video bit rate 128, o garso 16 (32 jei muzonas), dar gali nuleist frame rate iki 15.
Neprisijungęs yplon
« Atsakymas #19 Įrašytas: Sausio 25, 2008, 19:19 »
lagina ir atsilieka vaizdas nuo garso.
zodziu tu pats pabandyk tada sakyk, nes niekas nepasikeicia... ;D
