Autorius Tema: Problemos su W200 flashinimu  (Skaityta 6953 kartus)
Neprisijungęs Tomas86LT
0 kreditai Žiūrėti inventorių Siųsti pinigus Tomas86LT
« Įrašytas: Balandžio 05, 2008, 01:49 »
Nufleshinau savo w200 ir ijungus telefona raso "configuration error. please contact your network operator or service center", nieko negaliu daryt, tik priimti skambucius. Flashinau programa setool2lite1.11, naudojantis pagal cia http://forums.se-nse.net/index.php?showtopic=17855 pateiktas instrukcijas.
Tel informacija:
ChipID:8040,EMP protocol:0301
NEW SECURITY MODEL DETECTED
PHONE IS RED RETAIL PRODUCT
FLASH CID detected:52
Speed:921600
Flash ID check:897E
Flash props sent ok
OTP LOCKED:1 CID:51 PAF:1 IMEI:xxxxxxxxxxxxxx CERT:RED
FLASH CID:52 COLOR:RED
Model:W200i
Brand:Sony Ericsson
MAPP CXC article: R4JA011     prgCXC1250719_GENERIC_ME
MAPP CXC version: R4JA011
Language Package:BALTIC
CDA article: CDA102737/1
CDA version: R1A
Default article: cxc1250728
Default version: R4JA011
Operator: 000-00
USERCODE:0000
RESTORATION FILE NOT PRESENT
"R4JA011_CXC1250719_GENERIC_ME"
YOU MUST PERFORM FULL FLASHING FOR PATCH UNLOCK
naudojau W200_R4JA011_FS_BALTIC_RED52, W200_R4JA011_MAIN_GENERIC_ME_RED52 bei W200_CDA102737_1_R1A_GENERIC_BALTIC.
flashinimo logas:
Will backup GDFS now.
Speed:921600
LDR:061205 1354 HAN_DB2012_FLASHLOADER_R2B012_CXC1326738
Flash ID check:897E
Flash props sent ok
CSloader version:
070410 1405 HANCXC1327364_COMPACT_SEMC_CS_LOADER_1_R3B009
loader startup: executed
loader GDFS startup: executed
stated number of vars:1416
Found:980 variables
Found:290 variables
Found:146 variables
GDFS read all done, GDFS_xxxxxxxxxxxxxx.BIN written
Phone detached
Elapsed:95 secs.
Speed:921600
Flash ID check:897E
Flash props sent ok
writing D:\Instal\SE W200\W200_R4JA011_FS_BALTIC_RED52\W200_R4JA011_FS_BALTIC_RED52.fbn
CURRENT FLASH FILE CID:52
SSW uses complete hash, hash len is:2420
Will flash 121 blocks...
SSW loading returns:0
writing D:\Instal\SE W200\W200_R4JA011_MAIN_GENERIC_ME_RED52\W200_R4JA011_MAIN_GENERIC_ME_RED52.mbn
SSW uses complete hash, hash len is:6360
Will flash 318 blocks...
CSloader version:
loader filesystem startup: executed
Processing script...
Will execute script now.
Phone detached
Elapsed:320 secs.
Gal kas esat susidure su sia problema ar zinote kaip ja isspresti?
Is anksto dekui.
Ats.: Problemos su W200 flashinimu
« Atsakymas #1 Įrašytas: Balandžio 05, 2008, 09:08 »
Šitą failą išarchyvuok iš .rar ir suarchyvuok į .zip, tada pasileisk SET2L, MISC Files nurodyk .zip failą ir Flash. Telefonas turėtų įsijungt po to.
Kitą kartą forumo paieška pasinaudok, toks klausimas yra atsakytas šimtus kartų.
« Atsakymas #2 Įrašytas: Balandžio 05, 2008, 14:16 »
Pakeiciau is rar i zip, nuflashinau, taciau niekas nepasikeite. Dar pabandziau isnaujo ideti ws ir main, taciau taip pat ta pati problema isliko
Flashinimo logas:
FILE RECOGNIZED AS CUSTOMIZATION PACKAGE.
CDA:CDA102737/1
MODEL:Melinda Generic
VARIANT:BALTIC
LANGUAGE: EN
LANGUAGE: ET
LANGUAGE: LV
LANGUAGE: LT
LANGUAGE: RU
Speed:921600
Flash ID check:897E
Flash props sent ok
CSloader version:
Writing package...
chdir: 2
Directory not found, attempt to create
chdir: 2
chdir: 2
chdir: 2
Directory: W200_CDA102737_1_R1A_GENERIC_BALTIC/tpa/preset/custom/
CONTENT_DOWNLOAD_HOOK.itm (2048)
Customize.xml (1117)
FM_PICTURES_HOOK_3.itm (10240)
FM_SOUNDS_HOOK_3.itm (10240)
FM_THEMES_HOOK_3.itm (10240)
FM_VIDEOS_HOOK_3.itm (10240)
GAMES_HOOK_3.itm (10240)
SETT_RINGTONE_HOOK_3.itm (10240)
Phone detached
Elapsed:278 secs.
Gal W200_CDA102737_1_R1A_GENERIC_BALTIC failiukas blogas ?
« Atsakymas #3 Įrašytas: Balandžio 05, 2008, 14:41 »
Jo failai nėra blogi, tiesiog suarchyvavimas yra blogas. Programa kaip pirmą katalogą mato W200_CDA102737_1_R1A_GENERIC_BALTIC, tada tik. Prisegu ištaisytą Customize failą, turėtų padėt.
« Atsakymas #4 Įrašytas: Balandžio 05, 2008, 14:58 »
Viskas veikia, didelis dekui ;)
Neprisijungęs Ignas30
Įrašai: 45 | Karma: +2/-1 | Lytis: Vyras
11 kreditai Žiūrėti inventorių Siųsti pinigus Ignas30
« Atsakymas #5 Įrašytas: Balandžio 10, 2008, 17:56 »
sveiki, man ir buvo ta pati problema tik ant k310, aciu, padejo  :) :). Gal turit k310 lietuviu kalba? ir kazkur girdejau kad pakeitus k310 softa galima prilituot m2. ar tai tiesa? :smile:
  • SE K660; K850; ERI GA628; M600; K500
