Autorius Tema: k750 please wait screen  (Skaityta 21551 kartus)
Neprisijungęs ripsaw
Įrašai: 16 | Karma: +0/-0
21 kreditai Žiūrėti inventorių Siųsti pinigus ripsaw
Ats.: k750 please wait screen
« Atsakymas #20 Įrašytas: Birželio 18, 2008, 12:48 »
kokiu pvz patch? ir kur ju ieskot?
« Paskutinį kartą keitė: Liepos 23, 2008, 19:53 sukūrė ripsaw »
« Atsakymas #21 Įrašytas: Liepos 23, 2008, 19:55 »
O kame problema jeigu su xs++ flasini vienu softu o xs++ rodo kitoki? pvz
Flashing e:\se\k750_r1db001_emea1_red49\k750_r1db001_main_eu_1_cl_red49.mbn
19:37:01| Header type: BABE
19:37:01| 291 flashblocks
19:41:14| Finishing flash
19:41:14| Done flashing
19:41:14| Flashing was successful
19:41:16| Disconnected... Unplug the phone
19:42:17|
19:42:17| Attempting to open the interface...
19:42:17|
19:42:17| TURN OFF PHONE!
19:42:17| Hold 'C' button on phone and connect phone NOW.
19:42:17| You have 30 seconds...
19:42:17|
19:42:21| Baseband ID: 8040
19:42:21| Protocol Version: 3.1
19:42:21|
19:42:21| Sending db2010_cid00_prodid_p3l.bin...
19:42:21| Applet ID: 061113 1250 ALUCXC125872_COMPACTPRODUCTION_ID_LOADER P3L
19:42:21| This is a PRODUCTION_ID loader
19:42:21| Activating GDFS...
19:42:21| Phone name detected!
19:42:21|
19:42:21| Profiling SEMC phone...
19:42:21| Platform: DB2010
19:42:21| OTP CID: 49
19:42:21| EROM CID: 49
19:42:21| EROM Color: Red
19:42:21| IMEI: 35255701xxxxxx
19:42:21| Phone ID: K750
19:42:21| Region: EMEA_1
19:42:21| CDA: CDA102295/7   R2A
19:42:21| Firmware Version: R1AA008
19:42:21| EROM: n/a
19:42:21| Ready for operation!
19:42:44|
19:42:44| Sending db2010_cid49red_flash_r2b.bin...
19:42:45| Applet ID: 051207 0928 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2B
19:42:45| This is a FLASH loader
19:42:45| Now flashing filesystem...
19:42:45| Flashing e:\se\k750_r1db001_emea1_red49\k750_r1db001_fs_emea_1_red49.fbn
19:42:45| Header type: BABE
« Atsakymas #22 Įrašytas: Liepos 23, 2008, 21:34 »
Na tu tik FS skiltį įrašinėji, o ne MAIN, todėl jau ir nesikeičia Firmware version.
« Atsakymas #23 Įrašytas: Liepos 28, 2008, 19:25 »
Flashing e:\se\k750_r1db001_emea1_red49\k750_r1db001_main_eu_1_cl_red49.mbn << cia kartais ne main
19:42:17|
19:42:17|
19:42:17|
19:42:21|
19:42:21|
19:42:21| Firmware Version: R1AA008 o po flasinimo rodo kai ka kita
19:42:21| EROM: n/a
19:42:44|
??? atsakymo niekur gal neberasiu  :'(
« Atsakymas #24 Įrašytas: Rugpjūčio 01, 2008, 19:33 »
tai gali kas pasiulyt dar kanors?
« Atsakymas #25 Įrašytas: Rugpjūčio 01, 2008, 21:20 »
Kažkas ne taip čia pas tave. Po FW perrašymo, bandei patikrint kokia FW per telefoną?
« Atsakymas #26 Įrašytas: Rugpjūčio 03, 2008, 10:15 »
taip
« Atsakymas #27 Įrašytas: Rugpjūčio 03, 2008, 10:19 »
taip
Ir tipo nerodo normaliai naujos perrašytos? Gal failai vis dėlto yra senesnės versijos, nors pats pavadinimas pakeistas.
« Atsakymas #28 Įrašytas: Rugpjūčio 06, 2008, 21:44 »
tai kad bet koki FW irasius rodo Firmware Version: R1AA008. bandziau net walkmano fw rasyt bet ta pati rodo. toks vaizdas kad kazko neiraso. parasysiu logus paflesines su setool.
Įrašyta: Rugpjūtis 04, 2008, 16:56
Na stai logas be customize
Loaded 51 flash descriptors
ChipID:8040,EMP protocol:0301
PHONE IS RED RETAIL PRODUCT
FLASH CID detected:49
Speed:921600
OTP LOCKED:1 CID:49 PAF:1 IMEI:35255701198444 CERT:RED
LDR:051207 0928 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2B
Flash ID check:200D
Flash props sent ok
DETACH CABLE FROM PHONE.
REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK
THEN PRESS "READY"
Trying to launch embedded bootloader...
INT LDR:COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2
Flash ID check:200D
Flash props sent ok
FOUND: R1BD001_CXC1250092_EU_1_CA
Restore from:R1BD001_CXC1250092_EU_1_CA
HDR block not accepted,error:A9
writing E:\se\K750_R1DB001_EMEA1_RED49\K750_R1DB001_MAIN_EU_1_CL_RED49.mbn
CURRENT FLASH FILE CID:49
SSW uses dynamic hash, dynamic hash len is:291
Will flash 291 blocks...
SSW loading returns:0
Elapsed:298 secs.
Speed:921600
Flash ID check:200D
Flash props sent ok
THEN PRESS "READY"
Flash ID check:200D
Flash props sent ok
FOUND: R1DB001_CXC125952_EU_1_CL
Restore from:R1DB001_CXC125952_EU_1_CL
writing E:\se\K750_R1DB001_EMEA1_RED49\K750_R1DB001_FS_EMEA_1_RED49.fbn
SSW uses dynamic hash, dynamic hash len is:161
Will flash 161 blocks...
Elapsed:171 secs.
Speed:921600
Flash ID check:200D
Flash props sent ok
FLASH CID:49 COLOR:RED
Model:K750i
MAPP CXC article: R1DB001     prgCXC125952_EU_1_CL
MAPP CXC version: R1DB001
Language Package:EMEA_1
CDA article: CDA102295/7
CDA version: R2A
Default article: cxc125953
Default version: R1AA008
Operator: 000-00
USERCODE:0000
Elapsed:23 secs.
ar ne keista gal kokiu pasiulymu?
« Paskutinį kartą keitė: Rugpjūčio 06, 2008, 21:52 sukūrė ripsaw »
