Autorius Tema: padekit n91  (Skaityta 11398 kartus)
Neprisijungęs svaigulis
Robke |
padekit n91
« Įrašytas: Birželio 21, 2008, 11:10 »
mano n91 isijungineja ir neleidzia paveiksliuku ziuret kai bandau atidaryt raso kadf negalima atidaryti saugumo sumetimais. kas cia gali buti? ir softo perrasymas nepadeda :(
Duok durniui is kelio
Neprisijungęs meistrs :)
Įrašai: 283 | Karma: +5/-1
Ats.: padekit n91
« Atsakymas #1 Įrašytas: Birželio 22, 2008, 09:15 »
Pradek nuo to koks pas tave ragelis tiksliai yra. N91-1 ar N91-2. Cia visai skirtingi telefonai ir softai skirtingi.
Robke |
Ats.: padekit n91
« Atsakymas #2 Įrašytas: Birželio 22, 2008, 11:32 »
nu as nzn. pas mane 4gb tai cia turetu buti n91-1 as nzn bet gi seniau perrasydavau budavo viskas ok. as per nokia puslapi perrasineju
Ats.: padekit n91
« Atsakymas #3 Įrašytas: Birželio 25, 2008, 09:20 »
Man tokiu problemu nebuvo, bet gal tai pades kiek nors.
Formatting the hard drive is recommended before flashing. This is to
insure that applications that were installed on the device previously are
re-installed. If applications are not re-installed this may cause instability
of the device.
Once flashing is complete, the *#7370# (lock code – 12345) should be
entered in the keypad to ensure the old SW is erased.
The TPO (Tutorial, media content) content that was delivered with the device
is available to be reloaded on the device if required.
The end-user should be informed that their DRM protected content on
the HDD will not play after the device is flashed. They should back up
their Device before it is flashed. (C drive and HDD). Applications that
have been installed on the HDD may have to be reinstalled to play
correctly after flashing. The C drive can be backed up before flashing
with ´save user settings¡ with Phoenix. This will retain the DRM
protected content licenses contained in the C drive
Robke |
Ats.: padekit n91
« Atsakymas #4 Įrašytas: Birželio 25, 2008, 13:11 »
paprasciausiai suformatavau hard 4gb ir susitvarke  :)
Neprisijungęs sernas19
Įrašai: 65 | Karma: +4/-4 | Lytis: Vyras
7 kreditai Žiūrėti inventorių Siųsti pinigus sernas19
Ats.: padekit n91
« Atsakymas #5 Įrašytas: Lapkričio 09, 2011, 19:41 »
kas galetu padet su n91 4 gb  teles past restartojasi pasikrauna buna noramlai veikia o poto pakimba i knisa restart kas gali buti?
  • n95,n78, n91,6230i, w850i, w980i, u8650 custom Room,3310 custom
Ats.: padekit n91
« Atsakymas #6 Įrašytas: Lapkričio 09, 2011, 19:49 »
Galinis dangtelis gerai laikosi?
Ats.: padekit n91
« Atsakymas #7 Įrašytas: Sausio 11, 2012, 21:59 »
galinis dangteli snormalai naikosi bet tai db aplamai jungi tel ir tik baltas ekranas daugiau nk. net nezinau ka darit :(
Ats.: padekit n91
« Atsakymas #8 Įrašytas: Sausio 12, 2012, 17:48 »
Persirasyk fw per pfoenix gal baiksis tavo bedos :) jei nera gaves dregmes ir smugio
Ats.: padekit n91
« Atsakymas #9 Įrašytas: Sausio 12, 2012, 18:16 »
nei smugio nei dregmes negaves bet kaip bandau perasinet paspaudziu ijungimo migtuka tai per pc rodo kad nezinomas prietaisas ir viskas.
